Absolute and relative time on charts
I am reading A previously saved TDMS file. When I display the file on a waveform chart the time axis only has two choices absolute and relative with dates and times which I cannot adjust. What I want to display is the start of the waveform as zero time and stop at the end of file with that time representing the duration of the file. How can I do this?
Thank you
(2,242 Views)
RoyB,
Is there a particular reason you are using a chart? Have you tried graphing instead, either a waveform graph or an x-y graph?
If you wouldn't mind posting the TDMS file, I'll try to see if I can configure something so you can see the behavior you are looking for.
-Nick-
Nick C | Software Project Manager - LabVIEW Real-Time | National Instruments
(2,215 Views)
