About the filtered signal
Hello , I have two question about my filtered signal .
I try to input a signal and I try to filtered it(sample= 8000 , filtered = 500-1000 Hz , band pass filter ,type : bessel filter, order=2) . After it is filtered , it's amplitude is very low.
This is my first problem : Why the amplitude of my filtered signal is very low ?
And my friend find the second problem about my filtered signal .
He said : Why there is a pulse signal in your filtered signal in the zero of time axis ?
This is my second problem : Why there is a pulse signal in your filtered signal in the zero of time axis ?
I change the frequency , amplitude , order..... , but  the amplitude is still very low , and  a pulse signal exist in filtered signal.
I try to change the another filter ,and the result is still very same.
Who can give me some suggestions?
I put the vi program and sound file under the article.
(611 Views)
Accepted by topic author 劉彥均
The energy in your file is at lower frequencies than your band-pass window and is being attenuated by the filter.
(583 Views)
Hello , thank you for your help.
I try to filtered the signal from 10Hz to 50Hz. It is a great .
But I am very curious about  which the VI you use .
Because I use the power spectrum vi to see my power spectrum .
The result is very same, but my graph is on the time axis.
Can you give your  VI program ?
I want to know the principle .
(555 Views)
I just changed the default name of each axis on the front panel, no magic vi work. I did use a different function, FFT Power Spectrum and PSD.vi, and plotted the PSD which has units if V^2 rms / Hz instead of the V^2 rms output by Auto Power Spectrum.vi.
Be sure to wire the dt terminal of Auto Power Spectrum or it will default to a time step of 1 second, which will skew your data into appearing at a much higher frequency.
About Customizing Graphs and Charts
(497 Views)
I try to use the  FFT Power Spectrum and PSD.vi , but it is very weird.
So , I try to make (samples=8000 , fh= 1000 , fl=500) the same condition, and I adjust the waveform
right click==>properties==>scales label==>make the x-axis 2000 multiplier , 50 offset==>
make the y-axis 0.00525 multiplier , 0.002 offset
But , the PSD graph is still not the same as yours.
May you give the vi program to me?
(480 Views)
Can you give me your complete vi program?
I want to know why my program is weird.
(463 Views)
