07-05-2021 04:12 PM
Hello LabVIEW Community,
I am using Knick 766 Calimatic pH measurement device for the pH and temperature measurement data acquisition. There the output is in the form of voltage. the device itself can measure the temperature and pH value. the pH sensor contains a PT1000 temperature probe. there is only one output possibility and which can be positive or negative which depends upon the pH or pOH. I would like to know is there any possibility that I can measure both values at a time by using Ni daqmx device?
I am using NI-USB 6000 for pH value measurement and if anybody knows the solution, please do let me know?
Thanks in advance!
07-06-2021 01:31 AM - edited 07-06-2021 01:34 AM
Hi Shannara,
When you want to measure the Pt1000 signal with your simple USB6000 DAQ box then you just wire up a voltage divider using an additional resistor. Your USB6000 can only measure voltage signals…
(You surely learned about voltage dividers in (high)school/university/apprenticeship? Or read a book about it!?)
After reading the manual of your device I guess there will be a (bigger) problem: you cannot measure that Pt1000 signal in parallel to your Knick766! That device needs to measure the temperature on its own…
