ASCII to decimal number
Hello all,
I have array of ascii numbers which I need to translate into number.
I used type cast, to convert each byte into decimal number, then concatenate into string.
This string contains multiple ''space'' characters, so I cannot translate this string into number.
Please check VI in att.
Please for advise..
Thanks a lot.
Message 1 of 8
(1,483 Views)
Accepted by milan87
@milan87 wrote:
Hello all,
Message 2 of 8
(1,460 Views)
Or:
It's not clear what the \00 should do, separate numbers or end the one value...
The main problem in your solution is that the numbers are I32s. Converting them the characters (U8s) will give you 4 characters.
Message 3 of 8
(1,458 Views)
How are you getting this array?  It seems to me that you are doing something just a little off if you are getting an array of I32 values.  This looks like it is a C string, so I am guessing it is coming from a DLL.  You should be able to read a string straight from the DLL and then you just need Fract/Exp String To Number to convert it into a DBL.
GCentral
Message 4 of 8
(1,409 Views)
Accepted by milan87
I Think this is what you want:
Message 5 of 8
(1,391 Views)
Thanks all for quick support.
Values are from ftdi chip, which use dll, for sure written in C.
Message 6 of 8
(1,349 Views)
If it returns I32s when it should return U8s, something's suboptimal at best, wrong at worst.
Message 7 of 8
(1,341 Views)
I suspect you can do something more like this so that you have the string directly (one less conversion that needs done).
GCentral
Message 8 of 8
(1,312 Views)
