AI configuration error with LockinDEMO
Whenever I push the start button on the DEMO I get an error with my AI Group Configuration.
(2,552 Views)
Are you attempting to simulate a signal to see how the toolkit works or are you trying to use it with a piece of hardware that you have?
If you are simulating, make sure that "SW" is selected beside "Signal Generator" instead of "Off" before you push the Start button.
If you are using hardware you have then make sure you are referencing that piece of hardware on the front panel. Scroll the front panel over to the left and address your piece of hardware.
Let me know if that doesn't solve the problem!
Brian Spears
(2,536 Views)
