AGPNA Configure Average (default incorrect)
Gives SCPI error 124 on Agilent PNA
"Average Count (1)" -> implies default (1)
Actually is zero
IS-> :SENS1:AVER OFF;AVER:COUN 0;
S/B-> :SENS1:AVER OFF;AVER:COUN 1;
(3,184 Views)
Can you please provide some more information? Hardware, software, application? It would be great if you could be more descriptive so someone can try to answer your question. Thanks!
JenK
(3,168 Views)
"AGPNA Configure Average.vi" is the file name of an instrument driver downloaded from NI for controlling an Agilent PNA. The LabVIEW software seems to be incorrect. The numerical control titled "Average Count (1)" implies a default of (1) but the default of the numerical control is (0).
(3,162 Views)
Thank you for being more specific. Are you just giving this information so it can be fixed or do you have a question? As a workaround you can wire a numeric constant of 1.
Thanks!
JenK
(3,148 Views)
I fixed it by changing the default to 1. I just posted it to give information in case others ran into that same problem. I apologize for not being more detailed about the specific VI, where it came from, etc. in my original post. Is there a better place to post this type of info?
(3,142 Views)
I'll fill out a corrective action report for National Instruments - hopefully R&D will be able to fix it.
Thank you very much for posting the information. We appreciate it.
JenK
(3,138 Views)
