ADODC activeX control - Null Reference for Property node for Fields property of Recordset
Greetings all,
I'm having problems using some parts of the ADODC activeX control in a Labview ActiveX container.
the top level properties seem to work fine (like the recordsource and connectionstring), however, I am getting runtime errors when I try to use the Fields property of the Recordset property of the ADODC reference.
When I run the program, a pop-up window appears with the following error message:
Error 97 occurred at Property Node
Possible reasons:
Labview: Null referene was passed in as input
Help?
P.S.  I realize there are alternative methods for doing this such as the database connectivity toolset, however, I would like to try to figure this out.
Thanks!
(3,407 Views)
Hi Zoe,
Did you put indicators on inputs to the ActiveX Container to see if any of them were Null?  I assume you are starting with a very small program.  Could you post a picture of it?
Have a good one.
Brian K.
(3,390 Views)
Hi Brian,
I don't have a website to post an image. Do you know of one I could post the image to?
I have 2 indicators which work on the top level properties, but nothing works below it.
I have an adodc activex control in a labview activex container.
In the block diagram, the activex control reference is passed to an open animation block,
which, in turn is wired to 2 property nodes with the 'recordsource' and 'connectionstring' properties respectively. Here is some ascii art of one of the many attempts I've made:
Adodc_Toby --- 'Open animation' --------- Property Node
                                                           |       Recordsource --- 'Indicator
                                                           |         ConnectionString --- indicator
                                                           -------Property Node
        Recordset ------- Property Node
        Fields
The error I described earlier occurs on the Recordset Property Node.
If I delete that node and the fields node, then the 2 indicators show valid information.
The connnection string will show on the front panel:
Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\jasper\National Instruments\Work_related_Labview\labview.mdb;Persist Security Info=False
and the Recordsource indicator shows:
SELECT * from Jasper_DG535
I had entered these on the Front Panel control by right-clicking on the control and selecting ADODC properties
Coud you try to simulate this?
  Toby
(3,379 Views)
Hi Toby,
If you wan't you can attach a snipet of your code or a picture.  You can do this when you reply to a message and go to the attachment section of the post, and browse to the VI or image you want.  I think that would be the easiest way to see what you are trying to do.
Brian K.
(3,371 Views)
Hi Brian (or anyone),
Sorry for the delay getting back to you. Got super busy at work. Hope it's not too late to enlist your help.  Thanks, I somehow missed the 'attachment section' on your discussion group website.
In the attachment, I show the front panel, ADODC property page, Block Diagram, and the error message. When the error message appears, it highlites the offending 3 'blocks' on the Block diagram, which are entitled: Recordset, Recordset, and Fields.
Thank you!
   Toby
(3,332 Views)
Hi Toby,
Can you check to see if the reference is NULL going into the _recordset property nodes, just to make sure the error is correct?
Brian K.
(3,319 Views)
