ABOUT THE TWO COUNTERS OF THE AT-MIO-16-E
This is my question.I've an AT-MIO-16-E and I need the two counters to work simultaneously to acqquire two frequencies countinously.I can't find a way to let them work countinously:they always stop after an acquisition.I've tried to use a while loop in the example "Measure period" but while they are resetted and rearmed I loose some values.Is there a way to solve this problem?Can the counters of an AT-MIO-16-E count countinously?
Please help me.
(3,201 Views)
Have you tried "while" loop with shift registers?
Victor
"luiart" wrote in message
news:506500000008000000B4300000-1004225886000@exchange.ni.com...
> Please help me.
(3,201 Views)
Hello;
The counters at that board of yours can do event count continuously but not period/frequency measurement continuously. To do that, you will need either the PCI-6601 or PCI-6602 boards. I'm attaching an example VI which does that, but this VI only works for those two types of boards.
Hope this helps.
Filipe
(3,201 Views)
What kind of continuous ctr acquisition are you trying to do:
double-buffered interrupt driven so that you do not lose a single count
(use of circualr buffer)?
Well, It seems that you can only use a single gpctr with an AT MIO 16E for
this kind of continuous acquisition, what I have been doing for 11/2 year
as soon as nidaq 6.1 and upward allowed it. At the time, I remember
reading that AT MIO E and MIO E series in general could sustain this
continuous dbl-buffered circular buffer for only one ctr. Otherwise you
ought to use a dedicated counter card.
Also be careful with HF rebound from any home-made trigger unit. Could
tell you more about it. The NI drivers and associated hardware are
merciless in case of such rebounds.
luiart wrote:
> This is my question
> Please help me.
Regards
Gerard D'Ans (gerard.dans@laborelec.be)
Laborelec Rodestraat,125 B-1630 Linkebeek
tel 32 2 382 0568
fax 32 2 282 0241
ULB SMA (gdans@ulb.ac.be)
Blvd F D Roosevelt CP165 B-1050 Brussels
Tel 32 2 650 2515
http://www.ulb.ac.be/polytech/laborulb/index.htm
(3,201 Views)
