Hi Sir/Madam,
I am using ME9100/82 card from ICS electronics company to connect the computer with multiple
instruments. I first connect card with ME-D9/8 on which there are 8 RS-232
ports, and then use every port to connect one instrument. My question
are :
1. How can my program identify which port, i.e. what can I do in my
program to send a command to port 1 not port 2, for instance?
2. Can I send one command to the 1st instrument and the other command to 2nd
instrument at the same time?
3. I am using Labview to compile a program, and the version of Labview
that I am using is 6.0. How can I implement send several commands to
different instruments at the same time? Could you please provid
e a simple example in Labview 6.0 for the multiple ports communication?
4. Has any one used MKS 937A, MKS 600 Series and MKS 247 instruments? Could you please provide an example for displaying parameters in Labview 6.0?
Thanks a lot.
