A Thing of Nightmares. Recommendations when reworking abhorrent code?
@altenbach wrote:
@Ben wrote:
he crashes I have seen with diagram clean-up and very bad code, I think there is at about 65535 pixels wide.
Yes, the coordinates are I16 and there is no validation, making things go haywire once you step over the invisible boundaries. Bam!
From my experience, things tend to go awry before actually getting outside of those bounds. I've seen more than a few customers complain that they are "only" 20,000 pixels from the origin in one direction and have wires extending off into the block diagram ether. I'm sure you're not surprised to hear that those same customers tend not to use any source code control.
Message 61 of 68
(1,701 Views)
I think it should be I64 to future-proof it against ever-growing monitor sizes.  😄
Bill
CLD
(Mid-Level minion.)
Message 62 of 68
(1,690 Views)
Because I'm such a nice guy, I'll let you post this to the idea exchange so you can get all of those kudos.
Message 63 of 68
(1,682 Views)
Very good Idea!  Mr, Ko, when you post that make sure to include just how big you expect monitors to get.
HINT: LEDs will need to get @100 Times smaller for a 64 bit monitor to fit inside the Kuiper Belt. ( the hole in the middle for the sun is a negligible size).
"Should be" isn't "Is" -Jay
Message 64 of 68
(1,675 Views)
How do you drive a display that is 8 light-hours wide?
Message 65 of 68
(1,668 Views)
I am sure the G-Force 108000000000000000-ti will have no problem
=== Engineer Ambiguously ===
Message 66 of 68
(1,664 Views)
Press the cleanup button and go home for the weekend.
Bill
CLD
(Mid-Level minion.)
Message 67 of 68
(1,651 Views)
Have you seen what happens when you hit diagram cleanup? Smiley LOL At any rate, I am going home for the weekend.
Message 68 of 68
(1,619 Views)
