08-09-2018 12:33 PM
@Ben wrote:
he crashes I have seen with diagram clean-up and very bad code, I think there is at about 65535 pixels wide.
Yes, the coordinates are I16 and there is no validation, making things go haywire once you step over the invisible boundaries. Bam!
08-09-2018 12:42 PM
Seems reasonable. In 5 weeks when threads start arising berating myself and my code, at least you'll know where to direct him! Not to fret though, when he eventually stumbles across the subVI which this thread is about, I'll be the last person on his mind.![]()
08-09-2018 12:45 PM - edited 08-09-2018 12:46 PM
For future reference, how does one quote using the "@User wrote:" for responses? Haven't figured that out yet.
08-09-2018 12:51 PM
Just press the [QUOTE] Button. (The name will not show in the composition window, but will be there when you post unless you edit way too much in that exact area :D)
08-09-2018 01:02 PM - edited 08-09-2018 01:03 PM
Experiment. The quote button seemed to have had issues for awhile. I've just ignore it. Right now they both show nothing before "wrote". I want to see if it actually appears when I click post. So there is a bug, but it is just in the editor screen not showing that name.
EDIT: You're right. The names do appear with @ after clicking post. Thanks.
08-09-2018 01:03 PM
Ah, I see. To be honest I just overlooked it due to it's location. Never even saw it never to the font editing tools.
08-09-2018 02:23 PM
Well then don't forget to mark the solution!
08-09-2018 02:26 PM
Just can't help but have that feeling that someone out there is going to see this thread and post a better version of this code they've had stashed away! ![]()
08-09-2018 02:37 PM
I have actually worked with that exact code before! It had been used for about 8 years before I joined, so I didn't even mess with it. It's ok to leave it as is, it's not like the code rusts over time... 🙂
08-09-2018 02:41 PM
Glad to see I am not the only one! That is true, if only it became better over time!
