05-07-2007 06:44 PM
Hi everyone,
I don’t know why an error file is generated when I store data (in the TDM format) after a period of time. The worst part is that after this error appears, I neither open nor write in my TDM file. I’ve tried to open it in the Data Viewer.vi (which shows the channel groups and the channels of a TDM file) but it hasn’t worked. I attached the TDM and the error files.
Thanks in advance.
JC
05-08-2007 11:46 AM
05-08-2007 12:02 PM
Hi Jim,
Thanks for reply. It means that I definitely lost my data, that's too bad. At least, I would like to know why my TDM is corrupted or which generates it in order to avoid that. Do you have any clue when you saw my error file?
JC
05-08-2007 12:14 PM
05-08-2007 12:32 PM
05-08-2007 01:03 PM
05-08-2007 01:16 PM
-2558 usually occurs because you didn't close the file properly on a prior access.
Jim West
Summitek Isntruments
05-08-2007 02:00 PM
Thanks my friends for all your help, I will try to figure this problem out.
JC
05-09-2007 03:56 AM
05-09-2007 10:05 AM
Hi Andreas,
Thanks so much for helping me to restore my TDM file and trying to find the problem.
I made my program in LabVIEW 8.2.1 and the Appilcation (EXE) is made in this version; however the installer was made in LabVIEW 8.2. In LabVIEW 8.2.1, the NI USI version is 1.4.1 (I looked it in the Installer Properties\Category\Additional Installers\National Instruments installers to include). In LabVIEW 8.2, the NI USI version is 1.3.02695 (I looked it in the folder National Instruments\Shared\Product Cache).
On the other hand, the application and the installer are installed in a computer with the following characteristics:
Operating System: Windows 2000 Service pack 4
Processor: Intel Pentium 4 2.8GHz
Disk Space: 40Gbytes available:22Gbytes
256MBytes of RAM
As additional information, I attach the performance of this computer. (there is sometimes 100% of CPU usage. It is because the database stores data every minute and at that moment uses all the CPU usage but it's a little time until the program finishes storing the data)
Thanks again for your valuable help and please let me know if you need more information about this problem.
My regards,
JC
Note: I have another TDM file corrupted, so would you mind telling me how I could restore it?
