10-24-2017 04:35 AM
Hello everyone,
I'm doing a internship which using the labview to make a graph with the tolerance windows which draw the rectangular for in the xy graph, I succeed in making one window, but for the second window added, I found the last point of the first window interfere the first point of the second window, so I go there for help, These are the photos and vi I created.
Thank you for helping me.
Solved! Go to Solution.
10-24-2017 04:40 AM - edited 10-24-2017 04:40 AM
Hi Liidle,
put a point between your two rectangles using NaN for its x and y value.
(Background: you can always "hide" plots by using NaN values…)
On your VI: why do you use InsertIntoArray when you want to build an array? Use BuildArray instead…
10-24-2017 04:46 AM
Hello GredW,
I use the insert array because I've already create the array in the sub VI.
Your solution is the best!!!!
Thank you so much!!!!!!
10-24-2017 04:49 AM
Hi Liidle,
You still can use BuildArray to concatenate those two arrays coming from your subVIs. And you can easily create a 3rd input at the very same BuildArray function to put this [NaN, NaN] point in between…
10-24-2017 04:54 AM
example for using picture-background https://forums.ni.com/t5/LabVIEW/Draw-a-rectangle-in-a-graph/td-p/1815331
(but it only shows how to create one rectangle)
there may be a way of creating a complete picture first and then setting this as background,
but i don't know how at the moment.
example using multiple graphs https://forums.ni.com/t5/LabVIEW/How-to-display-simple-shapes-on-graph/m-p/1852041/highlight/true
it looks to me that you are using only one plot for both,
therefore you would have a connecting line between figures.
having multiple graphs as in the example above should solve that.
10-24-2017 04:59 AM
Hi GredW
I Tried what you said, I have to say, your advice is so useful!!!
Thank you so much.
Sincerely
10-24-2017 07:02 AM
I know using the multiple plots are simple, but the purpose is to realize multiple windows in the same plot.
Thank you anyway
Best Wishes
