Hello fellows,
I am doing a project and I would like to ask your help about one or two situations.
I am using two hall sensors (A1220) incorporated in a motor to measure the voltage, intensity and position of the motor. Could you please telling me if can used the same procedure that normally is used for encoder sensor? like DAQ Assit ( acquire signal, counter input and angular position) or with hall sensor or i have to go in a different away?
I am starting this but i am afraid when i go to test it it wont work because i am not setting the correct procedure.
I have also to convert my signal. Using a virtual channel and and a DAQmax READ I will be able to measure my digital signal from 0V till 14V?
ps: ( I am starting with LABVIEW and i already read a lot for it, i am having difficults to understand some parts. i hope u understand)
Thank u for help.
