Hi, I am having problems getting a piece of code that I originally wrote on my PC to work on my Laptop.
The code controls a stepper motor and sends and recieves data through an NI 6008 USB DAQ.
The program was fully debugged and worked well on my PC but when I transferred it to the Laptop a number of problems arose even though both PC and Laptop are running the same LabView version and NI DAQ 800.
At first the stepper motor would not respond to signals.. this was overcome by installing the VISA drivers (i don't know why these didn't install themselves when I set up the Laptop, as I didn't have to install them when I setup the PC)
Now when I run the program on the Laptop it only works when in debug mode (is there something wrong with timings? - do i need the place some delays in?)
Also I don't think LabView is talking to the DAQ software properly, When I run the measurement and Automation program, the DAQ is recognised and tests can be run sucessfully, however LabView is some what less successful, as it won't record readings from the DAQ when I give it the same stimulus.
(Are the drivers that can be downloaded like the VISA's which will allow my DAQ to work again?)
Cheers Wes
