‎09-04-2015 02:10 PM
I am seeing a trigger delay with the set up that I have.
cDaq 9188XT
9229 slot 1
9229 slot 2
9229 slot 3
9237 slot 4
9237 slot 5
9474 slot 6
9375 slot 7
9213 slot 8
I am using the high speed digital output to trigger multi high speed timed events. I am using channel 7 on the 9474 module to the PFI0 on the chassis to trigger the Analog data acquisition. This should happen at the smae time as the ch 7 trigger. When I get the data I see the actual trigger at around 4300 samles vs the 300 where I would expect it to be.
Channel setup is 10KHtz
5000 Sample
300 Pre trig sample
Any thoughts or ideas would be appreciated.
I tried to attach the code but it kept telling me that my zip file wasn't a zip file and deleating it.
‎09-04-2015 02:11 PM
Here is the analog trigger vi
‎09-08-2015 07:26 AM
Any help would be appreciated.
‎09-08-2015
03:32 PM
- last edited on
‎01-02-2025
04:52 PM
by
Content Cleaner
Hi YanFeng,
Just curious but have you tried to trigger the Analog data acquisition outside this application? This will help identify if it is code related or hardware related. This link may help: https://www.ni.com/en/support/documentation/supplemental/21/ni-daqmx-data-acquisition-triggering-tec...
Post back with your results.
‎09-18-2015 07:36 AM
The name is Tim, I work for Yanfeng.
I got this figured out. Thanks.
