06-21-2007 10:38 AM
06-28-2007 11:39 AM
06-29-2007 03:43 AM
Hi Sarah , thanks for your response .Im only using either two DIO write port or two writeline vi's within a while loop ( both about the same timings ). With first a 0 written then a 1.So i get a 1to 0 transition every 6mS. Im surprised since calls to the I2C and SPI vi's are very much faster doing similar repetitive calls. I think there must be some internal firmware trade off in the 8451 in favour of i2c and SPI.?
thanks dht
06-29-2007 05:44 AM
Hi dht,
The DIO lines on the 8451 are static and so are software timed. The SPI lines have got hardware clocks to control the data rates. With the DIO lines you're limited by the speed at which windows can update the driver and hence the output from the device. If you need faster DIO output rates you may need to consider a board with counters as these will have hardware timed digital lines.
07-07-2008 08:17 AM
