I am trying to set up a Hall effect test using the Keithey 7001 switch system and the 7012-s matrix card. First time using the 7012-s card.
Whenever I use the "open/close channel" VI to open or close a certain channel, I am getting "error -222: data out of range." The VI works fine, however, if I run "open all".
Can you try to make a new front panel control that doesn't try to set a channel or column?
Have you looked through the examples that came with your driver? Since it's one of the LabVIEW plug-and-plays it should have a few example programs that could provide guidance.
