-63040 Error, FPGA fails to run the code - sbRIO 9637
I have this trial single board rio from RIO (9637) and I have been trying to test it. But when ever I try to run a code on it's FPGA, it gives an error:
I do not get this error when I need run any code on the Linux real time system, RT side. Device is visible in the MAX. Required software/ firmware are up to date & are installed on the device. I tried most of the solutions posted online on NI.
Commonly addressed: https://forums.ni.com/t5/LabVIEW/LabVIEW-Error-Code-63040-on-sbRIO-9632/td-p/3109878?profile.languag...
Strangest part is, it sometime randomly works normal but only a couple of times and then starts giving out the same error. Codes are tested as I have been running them on myRIO and have reconfigured and compiled them for sbRIO 9637.
Can anyone help me with this? I have to test it and return it.
Message 1 of 1
(1,302 Views)
