I'm using MAX test panel to test my digital I/O pins, however i couldn't find any manual explaining the function of the test panel. there are 2 tab on DIO. what are the operation/function in the 2 DIO tab?
First Digital IO tab
a. which port does it test?
b. why can't i select the input state?
For the second Digital IO tab
a. i can only select port 2,3,4, what does the port 2,3,4 refer to? coz for 6025E, i have only port 0,1,2,3
b. why can't i set the input i want for the input port?
c. how i check if the digital IO port is reponding?
thks & best regards
