03-08-2013 01:41 PM
I'm trying to find out how to measure, from within a vi, the phase noise from a PXIe-5663E. I have the RFSA driver (v2.5.2 and v2.6), so I am able to measure, via the Soft Front Panel, the Phase Noise. I'd like to automate this process. Any suggestions? Thanks in advance.
03-08-2013 02:55 PM
You could try using NI I/O trace to capture the command sent to the 5663E when you use the soft front panel. In the NI I/O Trace options make that NI-RFSA is checked in the View Selection tab.
Ben64
03-11-2013 06:17 AM
That's a resonable idea, however, since it takes quite a long time I'm guessing it would be a sub-optimal solution (it basically sweeps across frequency). I'd much prefer to verify that there isn't a phase noise measurement VI or driver that could be integrated into my current VI's for automation. Either way, please let me know.
03-11-2013 09:13 AM
Yes, the measurement can be done in your own VI's:
http://zone.ni.com/devzone/cda/epd/p/id/5595
This will require you to use the NI Modulation Toolkit, and the Phase Noise measurement is actually a shipping example with the toolkit:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/210568
I hope this helps.
03-11-2013 09:20 AM
Yeah, I have the modulation Toolkit (comes with the NI-6553E), however, when I open this VI, it cannot find the "mod_Phase Noise Calculation.vi" Is this part of an older version of the modulation toolkit? I noticed this post was from 2009.
03-11-2013 10:39 AM
The missing VI should be found at (if using LabVIEW 2012):
"C:\Program Files\National Instruments\LabVIEW 2012\vi.lib\addons\Modulation\Analog\support\mod_Phase Noise Calculation.vi
In case you don't have it, I've attached the VI to this post as well.
