07-24-2019 06:39 AM
I am needing to create a VI to measure the force on a cantilever load cell to then control the force of a servo motor. The load cell amplifier being used is a ADS1115.
I know I can control the speed and and angle using the Arduino Servo Example in Labview. I am using a Arduino UNO. I have Pmod NAV 9-axis to cross check the angular velocity and angle of the servo motor, however this uses LINX firmware and the servo uses the Labivew Arduino interface thus I can't have both firmwares on one board. Do you simply have to choose the correct COM in the VI for the two different UNO'? Is it possible to run them in the same VI as I need to a graph from this at the same time for cross checking.
ARD
09-15-2020 01:28 PM
here is avi to read ads1115 (2 diferential inputs)
remember have to chanche the bits sended to chance the parameters of working
