5 LEDs are circulating one by one at 1 sec interval.( LabView VI)
Hi everyone, I am new user for LabView. May I know how to make 5 LEDs are circulating one by one at 1 sec interval.( In LabView VI). Thanks.
Message 1 of 12
(627 Views)
I only have a Rube-Goldberg-Machine for this problem. It may work for you or not ...
Joke apart:
It looks like an educational exercise and you should solve it by yourself. If you get stuck, then post your VI and we can help you with the next step.
Message 2 of 12
(591 Views)
There is actually an example of this in the actor framework project template! Take a look at the "launcher.vi" after loading the template
Studying for CLA.
LabVIEW, inherit from social media habits!
Message 3 of 12
(581 Views)
Your problem is much simpler than the problem solved here  (fewer LEDs, no random skipping, etc.). I am sure you can simplify it accordingly. Done correctly, the code will be trivial and fit on a postage stamp.
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 4 of 12
(557 Views)
Fantastic code and really funny in the details!. Definitely belongs into the Rube Goldberg thread. 😄
Message 5 of 12
(554 Views)
When you say "circulating", do you mean that the LEDs are arranged in a circle? (Thus my reply above).
If they are arranged linear, use an array of LEDs (have a look here). Of course there are many equally simple alternatives to solve this.
As an exercise, see if you can recreate the following code:
Message 6 of 12
(551 Views)
may i ask the what is the name of this tool? Thanks螢幕快照 2020-09-21 下午6.43.47.png
Message 7 of 12
(489 Views)
Hi David,
its a function to manipulate arrays, so it can be found in the array functions palette!
Hint: it does not insert, but replace…
using LV2020 on Win8.1+cRIO
Message 8 of 12
(483 Views)
another option would be to start with a boolean array constant (where one is true) and simply "rotate" the 1D array each iteration of your while loop.
Message 9 of 12
(471 Views)
I Heard good things about the Rotate function and number to boolean Array.
G# - Award winning reference based OOP for LV, for free! ADDQ VIPM Now on GitHub
"Only dead fish swim downstream" - "My life for Kudos!" - "Dumb people repeat old mistakes - smart ones create new ones."
Certified-LabVIEW-Developer
Message 10 of 12
(467 Views)
