08-09-2007 10:43 AM
I have a Watlow F4 temperature controller, which is re-transmitting via 4-20mA current
(what the temperature is in the oven.) I want to capture this current loop and convert
it to a temperature gauge. I have a current input into my VI coming from a cFP-AI-111
module on a cFP-1804 device; I've read that I need to scale the input using "slope of a
line (y=mx+b)" equation and I have included this into my VI plus my assumption that the
temperature will be in Celsius, I have included a conversion to Fahrenheit.
But my whole issue is the in-between - How do I convert the scaled number (or current
loop reading) into a temperature? I have used the scaling (numeric) functions (the three
thermocouple related) without success, none of the required info for the scaled vi-s
relates to the information I can provide since I have a current loop and no voltage. I
know temperature is usually read in voltage and adding a resistor to the current amd measuring
across this resistor to get voltage is the common thing. Am I out-of-luck here in converting
the current to temperature inside my VI from my cFP-AI-111?
I have attached the VI I have created - any help in figuring out what needs to be added would
be much appreciated. I have been working on this for a long time and would like to get this resolved.
Let me know if you need any further information.
08-09-2007 11:30 AM
08-09-2007 01:26 PM
08-09-2007 01:53 PM - edited 08-09-2007 01:53 PM
What I normally do to get the equation is place the points in excel and then graph it and use the linear trendline and display the equation.
We may be confusing each other with the C and F stuff. Normally what most current output temp sensors have is a certain current rating per Kelvin (for the AD590 it is 1uA/K). This gives you a range of -55 to 150 C, or -67 to 302 F.
Message Edited by Kenny K on 08-09-2007 02:02 PM
08-09-2007 02:30 PM
Thank you for your response - very helpful.
I was told part of my problem was the decimal point placement needed to be moved for converting from mA to Amps.
Here is a copy of my running VI.
Thanks again, Ian
