04-12-2021 08:30 AM
I have a Crio-9056
with a C-module in each slot.
The first 3 slots are filled with an NI-9476.
When I create a new project and add the automations modules (new> Target and Devices)
Does it add all modules to my project, except the 3rd NI-9476 module in slot 3 (but also if I put it in another slot)
If I try to add it manually (new> C Series Module), the system that the respective slot is already in use in this project sends out because of an NI9476.
So under my FPGA Target folder are 2 NI-9476
and in the configuration (FPGA Target (right mouse button) new> C Series Module) there are 3 NI-9476
What's going wrong here?
08-23-2021 11:27 AM
Hi there,
What an interesting case we got here! 🙂
First, let's reset the NI MAX configuration:
Second, let's make sure that all the NI-9476 are working well:
Third, if you have not seen it yet, check the following article: Adding a New C Series Module to a cRIO Project in LabVIEW
Forth, if all the steps were not effective, please share some screenshots of your project so I can look into it deeper.
Cheers,
