3d picture control redraw expensive?
Hi all!
I have a VI with a 3D picture control. This control is updated and set to redraw 10 times per second. The redraw method is called by:
The reference to the control is stored as a generic control reference, then casted to 3D picture control and lastly Redraw is called.
It seems that manual redraw calls are a bit expensive. With the redraw call, CPU usage hovers around 6 %. However, if I disable redraw and instead update the display by rotating the scene, then CPU usage drops to one percent.
Before I delve further, does anybody have any experience with this?
Regards
Lars Melander
Uppsala Database Laboratory, Uppsala University
Message 1 of 8
(4,187 Views)
Any reason why you're calling a manual redraw at all?
Message 2 of 8
(4,174 Views)
At the moment, the scene contains a football field, with a ball bouncing around. The ball position is updated 10 times per second. If I don't call redraw, nothing happens.
Lars Melander
Message 3 of 8
(4,169 Views)
Try changing it from a control to an indicator.
I've done 3D animations like this before and to be hionest, I haven'0t had your problem at all.
Message 4 of 8
(4,157 Views)
Accepted by topic author LarsM
Ah, I just double checked my code and saw that I also had a redraw node in there, but I wasn't using a control refnum.  My invoke node was tied ditrectly to the 3D graph and I have no refresh rate problems.
Also check that your graphics drivers are up to date.
Which version of LV are you using?
Message 5 of 8
(4,150 Views)
I'm using LV 2012. But now that you mention it, the invoke node is strict, so it should be faster. I will make a test.
Lars Melander
Message 6 of 8
(4,140 Views)
Yep, the strict call is better.
Lars Melander
Message 7 of 8
(4,137 Views)
Well then that's an interesting thing to know.
I was previously unaware of that.
Message 8 of 8
(4,127 Views)
