3d graph scale multiplier??
Please modify your example such that it uses constants for your data and try using the parametric plot (as I mentioned earlier).
For someone to help you with the example you posted earlier they would need;
1) LV 6
2) Similar hardware with similar test equipment
3) and a knowledge of the 3-D graph.
Those three req's are going to be very rare these days. So convert you example and please repost.
Trying to help,
Ben
Message 11 of 12
(857 Views)
hi! you're facing exactly the same problem as i did (i'm the threadstarter btw :D)
I'm using LV 8, so i don't know if my solution is available for you. in the 3dsurvace vi, there are input port for x and y vector (atleast in LV 8). By wiring a vector with the right dimension, you can alter values that are displayed in the x and y axis. Here's a screencshot for your modded vi. I try to fix the frequency axis for you. Maybe the values are still not correct, but i hope you get the ideas.
Best Regards!
Message 12 of 12
(838 Views)
