3d array to spreadsheet string
I need a spreadsheet string eliminating all rows [x, 0, 0].
Message 1 of 11
(1,631 Views)
Hi lesterino,
you can use the vi called Match Pattern to search the pattern you want to eliminate from the string and then use the concatenate string to concatenate the output of the match pattern before string and after string.
Hope to have understood what was your problem, but don't hesitate to contact me if you need any further help.
Bye.
Message 2 of 11
(1,572 Views)
Try changing it into a 2D array instead.
GCentral
Message 3 of 11
(1,554 Views)
Very interesting, simple, Thanks!
I ask you another question, how can I put a null row between each loops? The goal is to obtain a carriage return between the spreadsheet string loop values:
29.171098,-7.003361,0.000000
29.630650,-4.693034,0.000000
29.907520,-2.353773,0.000000
30.000000,-0.000000,0.000000
78.296261,0.000000,72.011625
78.054900,3.321259,72.011625
77.332304,6.622042,72.011625
76.132929,9.881998,72.011625
Message 4 of 11
(1,533 Views)
Any solution?
thanks
Message 5 of 11
(1,498 Views)
Convert the numbers to strings inside of the loop.
After each 2-D array, concatenate another linefeed to the string.
Message 6 of 11
(1,489 Views)
I tried to do this, but it does not work.
can you help me?
thanks
Message 7 of 11
(1,463 Views)
Well, you have mentioned your output but what exactly is your input?
CLAD
Passionate for LabVIEW
Message 8 of 11
(1,457 Views)
as you can see in test3.vi Block Diagram:
Input is a 3D array,
output is a speadsheet string
Message 9 of 11
(1,448 Views)
Accepted by Lesterino
Dear Lesterino,
you have three inputs on your "Concatenate Strings" between the shift registers. Change their order: the first input for the second input. Then the new data are pasted at the end of the data coming from the shift register. If you need a reverese order of the string (as it is now), you have to reorder the inputs on your "Concatenate Strings": 1. the line-feed 2. the new data string 3. the data from the shift register.
Cheers,
Message 10 of 11
(1,438 Views)
