09-05-2019 04:18 AM
Hi all
I have a problem (bug?) with 3D surface plotting: when running the program, the plot itself jumps some 1 cm up (or down), out of the frames. (See the attached pic) After quitting the program, the plot is similarily 1 cm low (or high) (i.e. still out of bounds). Resizing the element corrects the situation in edit mode, but the problem occurs again when running.
If I add a new 3D-surface with "create all constants", the similar happens. If I move the original graph to a new VI, no problems. I also added a frame with a breakpoint to be executed before anything else. No help.
Somehow my main VI seems to cause the problem.
I am using LabVIEW 17.0.1 64-bit
Jimi
09-05-2019 07:43 AM
The picture is nice, but you should attach your VI to see if we have the same problem.
09-13-2019 09:11 AM
I removed everything else but the 3D-image from my code, and still the problem occurs. I tried on two PCs - no change. The code is attached. I have to run it twice to get the effect. On the first run the image goes white (of course, there is nothing to show) but on second the image jumps.
Jimi
09-13-2019 09:13 AM
Hmm. Weird. Now that I download it from here, nothing happens.
Jimi
