3D picture creating a line between two coordinates
Hi every one,
i am trying to create a straight line using two points (0,0,0) and (1,1,1) in 3D picture.
After i try i see that i don't get straight line that starts and (0,0,0) the origin, and ends in (1,1,1).
i am using LabVIEW 19(no vision)
The question is:
How should I use LabView commands in order to transform a vector V0 (thin cylinder)  to vector V1, where:
V0 is along the Z axis, its length is sqrt(3)/2, and its center is at the origin
V1 is located such that its bottom part is at the origin and its top part at (1,1,1)
The transformation i have in mind is:
  1. Rotation o 45 degrees about the Y axis and then rotation of -45 degrees about X axis, in the world coordinates (fixed)
  2. Translation of the center of the cylinder from (0,0,0) to (0.5, 0.5, 0.5)
I added VI that i used to do it.
I need some help and thank you.
(2,848 Views)
I've not done much with 3D drawing in LabVIEW, but have a lot of experience with 3D rotations.  Given a right-hand XYZ coordinate system, here is how I would draw a vector from 0,0,0 to 1,1,1 (note that there are multiple ways to do this):
  • You need a vector of length sqrt(3) (Pythagorean Theorem).
  • Rotations leave the origin (0, 0, 0) fixed, so start your vector at 0, 0, 0, and point it along the Z axis.
  • I'm going to assume that the rotations leave the axes "fixed" (if this isn't true with LabVIEW 3-D, you should be able to work out how to do it).
  • Rotate about the Y axis until the Z coordinate is 1.  How much is this?  Cos(Yrot) = 1/sqrt(3), and the new "end" coordinates are (sqrt(2), 0, 1).
  • Now rotate about the Z axis by 45°, which brings the tip to (1, 1, 1).
(2,790 Views)
the center of mass of the thin cylinder is at 0,0,0
like this:
all the rotation you do is relative to this point
@RomDev wrote:
"i am trying to create a straight line using two points (0,0,0) and (1,1,1) in 3D picture."
to achieve this in a 3d picture control, use "create mesh with attributes"
..\LabVIEW 2019\examples\Graphics and Sound\3D Picture Control\Creating Points and Lines.vi
or do your own version of 3d Bresenham Algorithm:
e.g. https://www.geeksforgeeks.org/bresenhams-algorithm-for-3-d-line-drawing/
and use spheres exclusively
(2,766 Views)
Hi RomDev,
A universal approach is to create a cylinder of the right length. By default the cylinder center is at (0,0,0) and it is aligned along the Z-axis.
LabVIEW provides a tool to rotate the cylinder a certain angle around a given axis. You calculate the angle by using the dot product and the rotation axis using the cross product, as shown in the block diagram below.
So the block diagram above is going to move a vector from the Z-axis centered at the origin to the origin and end positions given by the controls ( (0,0,0) and (1,1,1) by default).
The VI is also attached here in LabVIEW 2019 format.
Regards
Marc Dubois
(2,693 Views)
