3D modeling for my pick and place
Hello
I am using labview with NI myRio to design an interactive pick and place machine. Therefore, by the end of this project the user should drag and drop different part into a 3D platform and hit run then the pcik and place machine would place linking logs according to the design. So, I am using labview to design a 3d model of building enviroment using labview. My goal is get something similar to build lego with chrome (https://www.buildwithchrome.com/) in labview, the main difference is I am using likning logs instead of lego. Therefore,  I am bringing the linking log into the labview and I am chaning the position of the rod with respect to origin. I want to be able to have mouse control instead of manually control of the position of the rod. Also, I was wondering if I can use a ring picture & text to have a drag and drop option from the ring picture into the 3d environment. Also, I have to have a good sense of x,y,z position because I have to send those data stepper motor for my builiding place.
Note: I cannot use extension of solidworks for labview because of constraint of the project. So, I have to design different parts in solidworks as a STL and bring them in to the 3D picture.
This is kind of what I have. https://www.youtube.com/watch?v=YahElWKf9ek
(2,502 Views)
Hi arahimi3,
Could you describe a little more what kinds of modules or toolkits you are using with LabVIEW for this project? For instance, how are you displaying the 3D models to the front panel?
(2,450 Views)
