02-11-2014 02:04 PM
02-12-2014
05:55 PM
- last edited on
05-22-2026
05:37 PM
by
Content Cleaner
Hi jab10015,
I want to make sure I understand what you're trying to do. From what I'm reading, you are trying to incorporate simulated heat sensors in SolidWorks, which would be gathering data from your SolidWorks model, and using LabVIEW to gather that data. Is this right?
The only SolidWorks support in LabVIEW that I can find is with NI SoftMotion, which is geared towards mechanical systems - primarily movement using motors. You can read about it here:
https://www.ni.com/docs/en-US/bundle/372876e/resource/372876e.pdf
I can't find anything regarding thermal readings from a SolidWorks model, unfortunately. Please let me know if the above article is useful, and if I can assist you in any other way. Also, if I am misunderstanding your project, please give me more information so I can understand better.
02-12-2014 11:08 PM
02-13-2014
09:56 AM
- last edited on
05-22-2026
05:38 PM
by
Content Cleaner
jab10015,
I initially saw this and asked Spicy to jump in because I thought you were trying to interface with Solidwords directly. Your latest post made me realize I had misunderstood the question, and I believe I have an answer for you. Just to make sure, you're wanting to take physical measurements and then map them on to a virtual 3D model within LabVIEW, correct?
If so, there is an express VI that you can find under the programming/graphics and sound/3d picture control/helpers that is called Sensor Mapping (provided you're running a LabVIEW 8.6 or higher). It sounds like it will do what you're after.
As far as documentation for it goes, you can find the manual page here:
A community example here:
https://forums.ni.com/t5/Example-Code/3D-Sensor-Mapping-Example/ta-p/3502246
And a solution for a common issue here:
http://digital.ni.com/public.nsf/allkb/2D8235CFB7C06A21862574BE00595B9B
