04-11-2019 01:43 PM - edited 04-11-2019 01:46 PM
Hi there problem solvers
I'm working on 3D plots here and have two of those damn things. The first is that I would like to have the X and Y axes of the plots inverted. Which looks like it works just fine... until you change the scale range in the graph. To me it seems like a bug, but maybe it's just me doing something wrong. Could someone test and verify?
The other is that I don't understand why the surface plot is transposed when switching from the matrix to the vector instance of the plot helper. Could anyone explain this to me?
Cheers
Mike
04-15-2019 11:23 AM
Hi Mike,
Can you give me a bit more information on what you mean by when you change the scale, it doesn’t behave correctly? Would you mind posting some screenshots on what you’re seeing versus what you expect?
04-15-2019 12:48 PM
