3D Picture Control clipping bugs AND very low FPS when adding a texture
My 3D Picture control code ran well for quite some time now until suddenly the framrate dropped down to ~1FPS. I rebootet and the bug was gone just to appear again some time later. In all cases without me changing the respective code (as far as i know). Now it seems persistent. I scrolled back a few weeks through my code repository and the bug now also occures in old code versions where im sure that it did not happen before.
During the investigation i disabled the textures and noticed that there is a depth check bug as well. In theese pictures http://imgur.com/a/3THva you see from top to bottom.:
1) picture taken from the side, green and red objects clearly hover over the brown box (sized like sheet of paper with hight = 1)
2) properties for each object in the scene
3) picture taken from below the brown box - the red and green objects should not be visible (behind the brown box from this perspective). The visibility of the red and green objects through the brown box depends on the viewing angle. It seems that some of the triangles of the brown box sometimes do and sometimes dont block line of sight - they appear more or less cut off. Cut off parts eigther are fully visible or not at all (no alpha blending between states).
After some hours of investigation i come to believe that its eigther a GPU (GTX 1070) or a driver problem (NVIDIA 376.53 - newest as of today) or does anyone have some other suggestions?
The main two points are:
- Why is a single 50kb texture applied to the brown box and looking ok bringing the framerate down from 60 to ~1 FPS?
- Why is the brown box not fully opaque? (i triied using Blending.Mode = On as well.)
Message 1 of 1
(2,594 Views)
