04-29-2019 05:58 AM
i'm new to Labview and trying to find a solution for this.
I have the problem that my 3d-graphs don't work when i use them on my current target.
Setup: Professinonal Development system; NI cRIO-9063; labview 32 bit.
When i use the 3d-graphs in a blank vi then everything works fine. but if i open the same vi on my current target (cRIO- 9063) then the graph is broken. Or if a open a new vi in my current target then the option to insert a 3d-graph isnt even there.
When i add a vi with a 3d-graph to my project with the target cRIO-9063, then in dependices i see several 3d files. In the Error list some of these files show up with errors like "Wire:Type not supported in current Target".
My Question is: Does cRIO- 9063 not support 3d-graphs (couldn't find anything to that on the internet) or didnt i take a necessary step so that the graphs work on that target.
Thank you for your help!
Solved! Go to Solution.
04-29-2019 07:53 AM
3D graphs are not supported on RT target (along with subpanels, Xcontrols, and 3D picture controls).
Se http://zone.ni.com/reference/en-XX/help/370715P-01/lvrtconcepts/display_developing/
