3 phase inverter
hi i am electrical engineering and search about a simulation code for 3 phase inverter on labview and in myrio
(2,236 Views)
Hi kreem,
We're probably going to need more than what you've written so far to give you any help.
In particular, since this is the LabVIEW forum, you can tell us what you're trying to do, what specific problems you're having, and how you'd like your (LabVIEW) code to behave.
At the moment, I can only guess that you're a (probably undergraduate) EE student, and you want to simulate a 3 phase inverter with LabVIEW using a myRIO.
  • What do you mean by simulate?
  • What do you want the myRIO to do? Should it measure something? Or you just want the code to run on it instead of a desktop? If so, how will you know if it worked?
  • What details are you planning on using as inputs or outputs to your "simulated inverter"?
GCentral
(2,068 Views)
