3.3V Serial Logic to CRIO
Hello all,
Long time LabVIEW-er, 1st time systems integrator (they Don't call it HARDware for nothing Smiley LOL )
I have a probe that has the following connection terminals:
GND: Ground ( 0V )
TX: Transmit ( 0 - 3.3V )
RX: Recieve ( 0 - 3.3V )
TRI: Transmit Interrupt (0V = Transmit 3.3V= Don't Transmit)
VIn: ( 3.3V In )
What is my best way to get this device connected to a CRIO system?
Currently I think my best bet is my NI 9401 module, but I also have the NI 9870. I'm open to buying something different if needed, but I would prefer not to. Any guidance would be greatly appreciated.
(3,019 Views)
Accepted by topic author JScherer
Is it a UART protocol?  Or is it something else?  If UART, then I would go with the NI-9870 and then use an RS-232 to LV-TTL adapter (for example: 232LPTTL33 from B&B Advantech).
(2,995 Views)
Thank you. If I'm using the  232LPTTL33  is there a way to get my VCC 3.3V and GND into my device?
(2,972 Views)
No, you will need a separate power supply for your devices.
(2,930 Views)
I purchased the device you suggested and everything is working as expected.
(2,917 Views)
