07-30-2014 02:26 PM
Sorry, I don't have IMAQ. Could you replace your image with a diagram constant of a 2D array?
Also, since your data is arranged in a grid, all you need is reshape to a 1D array (the picture array and the function output inside the model), you don't need this advanced coding that also works for scattered xyz data.
07-30-2014 02:35 PM
Here is an old example for this. (read the entire thread to fit for an elliptic peak of arbitrary rotation, see image below)
07-30-2014 04:12 PM
07-30-2014 05:05 PM
As I said, you should use code that is optmized for gridded data. There is no reason to do the xyz dance.
Here's a quick rewrite of my older code.
(simply read your PNG file, wat a few seconds, and it will fit it just fine. For faster fitting, you should take a reasonably sized subset around the peak)
07-30-2014 05:09 PM - edited 07-30-2014 10:45 PM
And here's how it would look taking a reasonable subset. Much faster! (same model VI as above)
07-30-2014 06:11 PM
Dear altenbach
Many thanks for your quick reply and help. I thought of using the subset too.
I will need a newer version to read your code. ( my one is 2012 ).
very appreciated your time.
xg
07-30-2014 06:56 PM - edited 09-16-2014 04:47 PM
Here's the LabVIEW 2012 version.
(EDIT: rezipped and uploaded new version)
07-31-2014 03:50 AM
Many thanks altenbach. I tested it. it is great.
the resaon I wanted to try this is that some of our spot (which is the light reflect from a ball) are disrupted by dust on the surface of the ball ( the part of edge of the spot be eaten away ) which affacts the centroiding calculation.
again, thanks for your help.
xg
09-15-2014 04:42 PM
I am having trouble extracting your zip file. It seems corrupt. Could you please re-upload a new version?
09-15-2014 06:57 PM
This thread contains 6 zip files. can you tell which one is giving you problems?
