2D array (image) orientation (suggestion for simpler method)
Hi all
How can I reshape an 2D boolean array as follow ?
(This is for printing on cylindrical objects such as a thick cord)
To this :
Message 11 of 19
(3,016 Views)
For more than 2 characters you have to make modifications.
JM
Message 12 of 19
(3,004 Views)
Message 13 of 19
(2,995 Views)
I have used your code (H-flip) and found that in some cases maybe it is incorrect. I have attached 2 images for your review.
Input: output array (output from another block)
Output: H-flip array
Do you have any suggestion?
Thank you 🙂
Message 14 of 19
(2,749 Views)
Compare your VI to the example mostly more carefully.  You didn't wire up the second part of the first array function.
\What is the point of adding zero to a number?
Message 15 of 19
(2,736 Views)
  • Next time just download the attached VI instead of wiring up an incomplete version yourself from scratch. 😄
Here is a better reference link
Message 16 of 19
(2,709 Views)
Thank you Smiley Happy
This wire is too small so that i could not see it...
"What is the point of adding zero to a number?"
---> I checked the operation of the your program...
"Next time just download the attached VI instead of wiring up an incomplete version yourself from scratch"
---> I am learning LabVIEW, so I want to do everything by myself Smiley Very Happy thank for your support
Message 17 of 19
(2,699 Views)
That zero does not exist in my program. In the other version, I insert the sign function. It operates on the remainder and increase the number of iterations by one if the size is not evenly divisible.
You should still download my code, run it side-by-side, and see if the results are different. Then do some probing and debugging to see where the wire values differ.
Message 18 of 19
(2,662 Views)
Why do I feel like a game of Tetris after reading one of Altenbach's posts?
Message 19 of 19
(2,644 Views)
