I need to solve a second order differential equation with LABVIEW with a 2D Runge Kutta of 4th order. Is there already a library that can help me?
I can manipulate my second order differential equation into a system of 2 first order ones. I than need a Runge Kutta in 2D which solves the system. Thanks Andrea
There is "Runge Kutta 4th Order.vi" but it's NOT available in the LabView Base Package. It's located on the Function Palette under Analyse >> Mathematics >> Calculus >> Differential Equations. Hope that helps
Instead of responding to a 14 year old thread, please start a new thread and explain exactly what problem you are having.
(If you insist on posting in Spanish, you should ask here instead.)
Google translated:
En lugar de responder a un hilo de 14 años, comience un nuevo hilo y explique exactamente qué problema tiene. (Si insistes en publicar en español, deberías preguntar aquí).
