2D Error Bar Plot - Visibility options for single plots
I connected eight "2D Bar Plot Helper" with a "2D Plot Class Obj Array"- cable to have these error bar plots in a common plot. This works fine, however, I am searching for a way to make single plots invisible/visible as needed. I could not find any option for this in the legend or any property nodes for changing it programmatically.
I would be thankful for any help.
(2,330 Views)
Code?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,289 Views)
Hey there!
@FinalDestillation Do you still bother with the issue?
If yes, could you please send your code that seems to be faulty?
(2,268 Views)
