2's complement
Hi anyone got any nice ways of converting 12bit 2's complement into its decimal format?
Message 1 of 22
(17,965 Views)
Hello Paul,
I hope, I that I understood right.
The VI in the attachment creates the 2´s complement and shows the decimal value. It´s for 8 bits.
Regards ThomasD
Message 2 of 22
(17,931 Views)
Hello PaulMc,
here is my solution to converting 12 bit Two's complement to decimal.
I hope I did not make any faults 🙂
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
Message 3 of 22
(17,907 Views)
Here is my solution.
Xu
Message 4 of 22
(17,886 Views)
Hello Xu,
your solution seems to have problems with negative numbers...
I included a similar method to yours in my example.
Message 5 of 22
(17,866 Views)
Hi guys
GerdW your solution worked best.
My own solution had a problem with 0x800, it would equal 0 and not -2048, but all other values worked.
Cheers
Message Edited by PaulMc on 10-25-2005 02:47 AM
Message 6 of 22
(17,864 Views)
Hi guys,
one more try - dac12bit.vi............ - used as sub.vi  for  12 Bit ADC  MAX168
with possibility to decide, if the IC is used in unipolar or bipolar mode.
Find it in Diagram of MAX168.vi   ( controlled via LPT - Port ).
Werner
Message 7 of 22
(17,832 Views)
Hi GerdW,
You are right, My vi was wrong. I forgot to set the default values of the "32-bit" controls on the frontpanel to FALSE.
Try this corrected one, please. Hope no error this time.
Thank you,
Xu
Message 8 of 22
(17,807 Views)
Did I modify this correctly to work with 16 bits?
Message 9 of 22
(17,715 Views)
sorry Christian,
if you would send your code again ....- with   LV 7.1 code attached
not everybody around has already upgraded to LV8
Werner
Message 10 of 22
(17,704 Views)
