07-26-2014 09:07 AM
P@Anand wrote:
In the "find list" are you getting the detected devices and are you sure its not empty?
Once that is detected then only its going ahead...And I am sure that is not empty and after I got reponse from this COM port next time when I wrtie to other COM port then I am getting timeout value.
07-26-2014 09:08 AM
Is it always the same serial port you time out on the XP machine? If so maybe you have an is with your hardware.
07-26-2014 09:09 AM
@Neos wrote:
are you using usb to serial convertor?
Try to check both com ports from MAX.
are you sure you did not change the usb to serial cable which was working eariler?
the code you have shown is horrible , it is very difficult to check what is happening.
now if this code is developed by you , you should start thinking about design architectures.
No I am not using any serial converter. Both com port is there at device manager and also at MAX. There is no cable involved.
I know code is horrible. I never worked on any design architecture so I am not good at it. What else cause this issue
07-26-2014 09:11 AM
Yes same serial port is posing timeout issue.
Same hardware is working on my development PC in which WIN7 is there
07-26-2014 09:13 AM
still there is a physical cable that goes from your PC to device.
Try to check if you are using null modem cable.
alternatively did you do loopback test on faulty port???
07-26-2014 09:16 AM
Same cable same hardware and all testing setup is workin fine in my development PC (WIN7).
One cable is for arduino which is standard B type. Other is micro USB
07-26-2014 09:21 AM
and in MAX you are getting results.
on other PC also
07-26-2014 09:23 AM
You could write a quick test program and due a loop back test to check your com port and see if you still get timeouts. This would rule out any hardware and os issues. Are you using the same rs-232 cables for production and testing?
07-26-2014 09:26 AM
If you do a loop back test I would short tx-rx (2-3 pins in d-sub) to check all hardware and cables.
07-26-2014 09:30 AM
NO RS232 cable........No next time my COM port which posed problem during testin doesnt work. I need to reconnect again to make it work
