2 Analog Input don't work together
I am doing a project using usb 6221 and DAQmx.
Using 2 IR Sensors to measure the distance
Everyone of them work good individual but together i get an 50301 error
The problem is I can't use two IR's Together and get the measures from them
How can i solve this problem to get the values from 2 sensors.
Message 1 of 14
(3,475 Views)
You should be able to use two at a time. Do you have any LabVIEW code that we can look at to see what you are doing? Also a sketch of how the sensors are connected to the 6221 will also be very helpful.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 14
(3,472 Views)
This is the vi of one IR sensor.
Message 3 of 14
(3,454 Views)
You can only have one AI Task running on that device at at time.  You can however, configure the Task to have both channels
"Should be" isn't "Is" -Jay
Message 4 of 14
(3,446 Views)
How i can do this?
Message 5 of 14
(3,439 Views)
@El-Awny wrote:
How i can do this?
Inside the DAQ Assistant, add another channel.  You will need to get rid of the other VI for the second sensor.
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
Message 6 of 14
(3,428 Views)
I have done this already but i can't extract the data of 2 Sensors from the Daqmx.
Only One Sensor i can get its data.
Message 7 of 14
(3,425 Views)
Where is your code showing this attempt?  Do you have the wires hooked up correctly to the second sensor?
aputman
Message 8 of 14
(3,423 Views)
This is the code
and yes the wiring is right
my problem when i put the 2 sensors in One Daqmx .. I get one read from 1 sensor .. i can't the other ( The indicator is a numeric data of 1 sensor not an array )
Message 9 of 14
(3,418 Views)
In the DAQ Assistant select Add to Add the other channel
Message 10 of 14
(3,409 Views)
