2 Analog Input don't work together
I am doing a project using usb 6221 and DAQmx.
Using 2 IR Sensors to measure the distance
Everyone of them work good individual but together i get an 50301 error
The problem is I can't use two IR's Together and get the measures from them
How can i solve this problem to get the values from 2 sensors.
Message 1 of 14
(946 Views)
You should be able to use two at a time. Do you have any LabVIEW code that we can look at to see what you are doing? Also a sketch of how the sensors are connected to the 6221 will also be very helpful.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 14
(943 Views)
Highlighted
This is the vi of one IR sensor.
Message 3 of 14
(925 Views)
You can only have one AI Task running on that device at at time.  You can however, configure the Task to have both channels
Message 4 of 14
(917 Views)
How i can do this?
Message 5 of 14
(910 Views)
@El-Awny wrote:
How i can do this?
Inside the DAQ Assistant, add another channel.  You will need to get rid of the other VI for the second sensor.
aputman
LabVIEW 2017
LabVIEW Programming
Message 6 of 14
(899 Views)
I have done this already but i can't extract the data of 2 Sensors from the Daqmx.
Only One Sensor i can get its data.
Message 7 of 14
(896 Views)
Where is your code showing this attempt?  Do you have the wires hooked up correctly to the second sensor?
aputman
LabVIEW 2017
LabVIEW Programming
Message 8 of 14
(894 Views)
This is the code
and yes the wiring is right
my problem when i put the 2 sensors in One Daqmx .. I get one read from 1 sensor .. i can't the other ( The indicator is a numeric data of 1 sensor not an array )
Message 9 of 14
(889 Views)
In the DAQ Assistant select Add to Add the other channel
Message 10 of 14
(880 Views)
