03-26-2012 12:49 AM
Hi all:
I have an ACX1553 board with 4 channels bought from.
Now, I want use 2 Channels to communicate with each other, one server as BC,the other RT.
And I used the example of "BC Acyclic Example" in AIM_1553 project.
My problems are:
1,Does "ul_Stream" means channel?"API_Stream_1":channel1? If yes, that means I should confining API_Stream_2 with the same VI.
2,Does "bModule" means the board in the PXI'S slot ID?
3,Does I choose "Direct Coupling"? I didn't use the transfer.
4,Would somebody so kind enough to send me an example about two channels communication?
05-08-2012 02:58 PM
Admin3,
Did you ever get this to work? I have an ACX1553-3U-2 (2 Channels), and I'm trying to do a similar thing - set Channel 1 to BC and wrap it to Channel 2 as an RT.
However, I can't seem to communicate with 2 streams within the same VI. I get NOACK errors from BIU2 when I try to configure API_Stream_2.
05-10-2012 08:31 AM
Yes, It can't work.
