06-01-2020 05:35 AM
I am trying to install LabView on my computer but the error:-126308: Error '' occurred when installing NI Package Manager keeps popping up every time.
I have tried to troubleshoot it by allowing the NI Package Manager through firewall and also checked my Windows updates. But I can't seem to find the issue.
Could somebody help me out
Solved! Go to Solution.
06-01-2020 10:17 PM
That is described as a Package Manager error, all right. If I were there watching what you were doing, or (better) doing it myself, I could notice some things like "How much free space is there on this machine?", or "What OS is being run?", or "Where did the Installer come from?" or "What Version of XXX was chosen", or ...
How about "filling in the blanks", including a screenshot of the Error Message (although I hate pictures, but some information is better than none)?
06-02-2020 12:57 AM
The installer that I used for downloading is from the NI software products website:
https://www.ni.com/en-in/support/downloads/software-products/download.labview.html#346254
My machine has a free space of around 300 GB left and is operating on Windows 7 Ultimate with 64 bit OS with 8 GB RAM
I am trying to download the LabvVIEW 2018 version on my desktop and am facing with this error:
06-02-2020 07:16 AM
This is the Error message:
Error -1066598274 occurred at an unidentified location
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (-1066598274) or for its hexadecimal representation (0xC06D007E).
If you search the Web for 0xC06D007E, you will find "0xc06d007e Error Codes are caused in one way or another by misconfigured system files in your windows operating system. " This suggests something might be slightly awry with your Windows 7 system. It is also possible that the newer installer, designed for LabVIEW 2020, might not work in Windows 7 (LabVIEW 2020 is not listed as "compatible" with Windows 7).
Do you have access to a Windows 10 PC to try your installation?
06-02-2020 07:27 AM
Currently I don't have access to a Windows 10 operating system, but I tried installing the LabVIEW software on another Windows 7 device and it worked out to be fine, so I guess there's something with my Windows 7 system,I'll look into it
06-02-2020 11:34 AM
Yes, that is precisely the meaning of the Error Message, as I explained in my previous Reply.
06-02-2020 11:44 AM
Ya sure
Thanks for your help
