02-02-2018 03:16 AM
Hello All,
This is Shashank Kamble.
We have a following system configuration & facing the error as attached.
Following is the scenario for the Error-
However while running BUS Monitor for CAN Port we are getting following error-
"Error-1074384895 occurred at Check Runtime Error.vi."
We tried to locate the nixnterr.log . However it wasn’t created.
Can you please guide us how we can troubleshoot this error?
Thank you in Advance!!
Shashank Kamble
12-15-2019 04:34 AM
i also have the same problem, without any soluation。
12-15-2019 06:22 AM
Sadly, the bad news is that the error mentioned in the title doesn't exist! Unfortunately, the actual error, -1074384895 no longer is listed in current LabVIEW installations (I have LabVIEW 2016 through 2019 installed, and I get "This error code is undefined."
Your best bet is to contact National Instruments. However, you are using extremely old software, including Windows XP -- the most likely solution would be to install Windows 7 (also near "end of life") or Windows 10 and a more current LabVIEW version.
12-15-2019 10:13 AM
Google is your friend. Google your error code (with enclosed in quotation marks to include the negative sign) and you get lots of hits. I can't guarantee the quality of said hits, but there is a lot of stuff for you to look at.
