韓国語の表示
LabVIEWで韓国語を表示することはできますか?
Windowsの言語設定で、韓国語を追加しましたが何も変わりませんでした。
添付ファイルでは、ネットから文章をコピペしています。
中国語は最初から表示されていました。
韓国語を表示させるにはLabIEW側で設定が必要でしょうか?
どなたか分かる方がいらっしゃいましたら、よろしくお願い致します
Community Edition
Version 21.0.1(32-bit)
(1,376 Views)
To change the language of your LabVIEW environment you have to uninstall your current version and then re-install LabVIEW in your preferred language. However, 64-bit versions are only available in English.
You can find more details here.
(1,336 Views)
Thank you for your suggestion.
However, I would like to use Japanese and Korean at the same time. Will I be able to use Japanese when I install the Korean version?
(1,297 Views)
Accepted by shinchanfx
Unfortunately I don't think that's possible with a single installation. But you could try downloading two different installations: one in Japanese and the other in Korean, both in the same machine/computer and see if that works out.
(1,285 Views)
I understand that it's difficult to do everything with one piece of software.
I'll consider whether to install both Korean and Japanese.
Thank you very much for everything.
(1,237 Views)
