11-28-2021 04:06 AM
Labview 公式节点中次幂怎么表示,是如图两个星号这样表示吗
11-28-2021 11:56 AM - edited 11-28-2021 11:58 AM
Translated by Google: "How to express the power in the Labview formula node? Is it indicated by the two asterisks as shown in the figure?"
If you have a question, please attach a simple VI containing your formula node and typical input values. We cannot debug images! Do you get an error?
Personally, I recommend to eliminate the formula node and use plain graphical code. Much simpler! Here's the power of x function.
11-28-2021 12:30 PM
Are you sure your formula should not be:
fi=f1*((f2/f1)**(i/(N-1)));
instead of your:
fi=f1*((f2/f1)**(i/N-1));
11-28-2021 12:54 PM - edited 11-28-2021 01:01 PM
Here's how it would look with the above correction.
One possible alternative without formula node is shown below. Same result! (There are many ways to do that!).
Note that the same can be achieved with the ramp pattern set to logarithmic (bottom). That's what I would use!
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
